June 29, 20214 yr comment_511430 Hi looking for recommendations for a Cat 5 tester, I’m not looking for a cheap LED flash through, I want to know the cable length, ideally if there is a break in the cable etc. I saw there are testers which will flash the port they are plugged into, that would be an added benefit. Main reason for looking is I have an Avigilon system where 2 cameras are offline, no led on the Ethernet port at the camera, IT have upgraded some equipment and I’m wondering if not all ports are configured correctly, problem is I don’t know where it’s connected to in the switch thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44641-cat-5-cable-tester/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 29, 20214 yr comment_511431 I have a chinky tat one than is slung in the van https://www.ebay.co.uk/itm/303417798295?hash=item46a51c2e97:g:QZsAAOSwz-dgjDuF Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44641-cat-5-cable-tester/#findComment-511431 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
