Smithy Posted November 17, 2020 Share Posted November 17, 2020 I have some ongoing issues with alarms. An understatement for sure especially for someone not in the trade . On a rear exit door is a magnetic door sensor. On replacing the battery firstly the alarm did not go off as per the other sensors, but also were blue and red lights on the frame sensor. These went away, but the alarm does not set (pyronix enforcer), and oddly when you put your finger near the sensor the blue light comes on. Any help appreciated Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44217-door-sensor/ Share on other sites More sharing options...
al-yeti Posted November 17, 2020 Share Posted November 17, 2020 1 hour ago, Smithy said: I have some ongoing issues with alarms. An understatement for sure especially for someone not in the trade . On a rear exit door is a magnetic door sensor. On replacing the battery firstly the alarm did not go off as per the other sensors, but also were blue and red lights on the frame sensor. These went away, but the alarm does not set (pyronix enforcer), and oddly when you put your finger near the sensor the blue light comes on. Any help appreciated Blue light meaning PIR? So finger near it would be normal Maybe cover isn't on correctly or you snapped the back tamper plate? Door sensor may not have triggered alarm if battery was completely flat perhaps 1 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44217-door-sensor/#findComment-506394 Share on other sites More sharing options...
Smithy Posted November 17, 2020 Author Share Posted November 17, 2020 Thanks for the thoughts but its not a PIR. It's a surface magnetic contact with tamper Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44217-door-sensor/#findComment-506395 Share on other sites More sharing options...
al-yeti Posted November 17, 2020 Share Posted November 17, 2020 1 hour ago, Smithy said: Thanks for the thoughts but its not a PIR. It's a surface magnetic contact with tamper Mashed up the board or tamper when you put.batyery in? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44217-door-sensor/#findComment-506398 Share on other sites More sharing options...
