John G
Hi I'm Installing a ACCENTA Alarm Panel together with a PyronixV2 speech dailer, and I'm not sure how to connect up the auto dialer to the alarm panel any help would be apricated thanks
The speech dialler has a
Negative
Positive
Trigger
Phone connections
As a basic
Negative to negative
Positive to 12v+ aux
Trigger can connect to the bell trigger which you may need to setup on the v2tel side after
Phone connections to 2&5 of your extension socket , not the master side will be easiest for you
Although if you got opportunity to return the dialler and get a GSM version you maybe better off future wise
