July 15, 20206 yr comment_503426 Hi everyone, I have an old house with a Logic 4 key operated alarm system fitted. I need to change the old grotty looking PIR sensor for a new one. Can anyone help advise what mode or procedure I have to put the alarm box in to swap out the PIR please? Box is the same as this one; https://www.picclickimg.com/d/l400/pict/233496060845_/Logic-4-key-operated-home-alarm-system-intruder.jpg Any help would be much appreciated. Cheers Ben Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43966-logic-4-pir-replacement/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 15, 20206 yr comment_503427 If it's that old I be thinking of replacing more than just one grotty PIR. They are old and basic don't have any engineer modes so it's just isolate the voltage so you don't blow stuff and either disable or silence the tamper as they occur. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43966-logic-4-pir-replacement/#findComment-503427 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 15, 20206 yr Author comment_503429 42 minutes ago, sixwheeledbeast said: If it's that old I be thinking of replacing more than just one grotty PIR. They are old and basic don't have any engineer modes so it's just isolate the voltage so you don't blow stuff and either disable or silence the tamper as they occur. Thanks for that! I assume with the mains disconnected there is a backup feed as the sensor still appears to flash red when I trigger it? When you say isolate the voltage, are you meaning to ensure the cables are kept isolated from one another when removing them off the old PIR? Longer term I will be swapping the alarm for a wireless system but for now I just wanted to make it look neater as the whole room has been replastered and painted. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43966-logic-4-pir-replacement/#findComment-503429 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 15, 20206 yr comment_503430 There is a battery in the control panel this is something that requires periodic checking and replacement. Isolating the voltage either from the terminals in the panel, or you can remove the mains and battery but that should trigger the outside sounder if the system works correctly. You could as you say just swap it live and make sure they don't touch but that risk is up to you. If your doing work in the house I would personally recommend wiring with proper alarm cable to sensor positions over a wireless system. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43966-logic-4-pir-replacement/#findComment-503430 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 15, 20206 yr Author comment_503431 4 minutes ago, sixwheeledbeast said: There is a battery in the control panel this is something that requires periodic checking and replacement. Isolating the voltage either from the terminals in the panel, or you can remove the mains and battery but that should trigger the outside sounder if the system works correctly. You could as you say just swap it live and make sure they don't touch but that risk is up to you. If your doing work in the house I would personally recommend wiring with proper alarm cable to sensor positions over a wireless system. Spot on, thank you! I'll see how I get on later today. Agreed on the wired system, unfortunately didn't consider this until finishing multiple rooms. So wireless is my only real option now Cheers Link to comment https://www.thesecurityinstaller.co.uk/community/topic/43966-logic-4-pir-replacement/#findComment-503431 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
