Hello
Please don't post the same question in multiple threads
  • Replies 21
  • Views 7k
  • I think you’re using the wrong commands to set and unset your alarm, you should be using S to set and US to unset so if your code is 1234 then you would use 1234 S to set and 1234 US to unset (I don’t
  • Glad it worked, I think its just P for part set, have a look at the list below:     I'll see if i can find a link to the update manual for you
  • There are various versions of the user manual that have slightly different commands, such as A and H for arming and disarming (as you found out). The manual I have uploaded is as close to my original
You should be able to set them up like this
On 20/10/2018 at 15:33, MaxX said:
That's great to know - I just installed a GSM module too. Waiting for my giffgaff sim to arrive. What SIM do you use?
Also can you add multiple Follow Mes for the text e.g:
code FMPHONE n NEW number
1234 FMPHONE 1 NEW 07123456789 (FOR ME THE GRAND MASTER)
4321 FMPHONE 2 NEW 07912345678 (FOR USER 2 - THE WIFES PIN)
