October 20, 20188 yr comment_480104 22 minutes ago, SeanT said: Yes you can, I used m2m (machine 2 machine) they ensure you sim will never expire Ah great thanks - I was looking at a global m2m sim too - may try the gifgaff first and see how well that works. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/page/2/#findComment-480104 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 20, 20188 yr comment_480105 13 minutes ago, SeanT said: ok, I think you need to go into engineers menu using * 0132 Then go into programming # Then system # then controls # the communications # Fm enable half unlock symbol (y/n) Cool thanks for that - I’ll try that later. I also want my cloud connection to use IP first / then GPRS if IP not available - I saw the setting for that in: Programming > Communication > Cloud Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/page/2/#findComment-480105 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 20, 20188 yr Author comment_480106 5 minutes ago, MaxX said: Cool thanks for that - I’ll try that later. I also want my cloud connection to use IP first / then GPRS if IP not available - I saw the setting for that in: Programming > Communication > Cloud Can’t really comment on that as I don’t have my system set up like that but hope it works Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/page/2/#findComment-480106 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 23, 20188 yr comment_480179 On 20/10/2018 at 20:15, SeanT said: Can’t really comment on that as I don’t have my system set up like that but hope it works Just put my SIM in today - added all the FM numbers - did an FM test from the user menu too, FM test basically called my mobile number.. I have a question about arming, I know the GSM is working as it is giving me a status message by text, however when I do an ARM or HOME ARM command: 1234 A OR 1234 H It does nothing, No message from panel - checked panel still showing Ready and I did "1234 ST" for status message - got SMS from GSM module that the system is Ready. Does your SMS arming work? Did you have to do anything else? Thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/page/2/#findComment-480179 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 23, 20188 yr Author comment_480180 I think you’re using the wrong commands to set and unset your alarm, you should be using S to set and US to unset so if your code is 1234 then you would use 1234 S to set and 1234 US to unset (I don’t think it’s case sensitive and you can omit the space if you want to). There is a list of commands in the user manual. Hope this help Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/page/2/#findComment-480180 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 23, 20188 yr comment_480184 37 minutes ago, SeanT said: I think you’re using the wrong commands to set and unset your alarm, you should be using S to set and US to unset so if your code is 1234 then you would use 1234 S to set and 1234 US to unset (I don’t think it’s case sensitive and you can omit the space if you want to). There is a list of commands in the user manual. Hope this help That is awesome mate - just tried your commands and they work - S for SET and US for UNSET Do you know the command for Part Set - I assume 1234 PS? I am looking at my manual dated June 2013 which informs us to use A FOR ARM, H FOR PART ARM, D FOR DISARM....which is obviously incorrect... Do you know where I can get the latest User Manual from? Thanks Edited October 23, 20188 yr by MaxX Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/page/2/#findComment-480184 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 23, 20188 yr Author comment_480185 Glad it worked, I think its just P for part set, have a look at the list below: I'll see if i can find a link to the update manual for you Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/page/2/#findComment-480185 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 23, 20188 yr comment_480186 Many thanks - appreciate your help with this! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/page/2/#findComment-480186 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 23, 20188 yr Author comment_480187 There are various versions of the user manual that have slightly different commands, such as A and H for arming and disarming (as you found out). The manual I have uploaded is as close to my original paper copy as I could find, however, it is slightly different but for most things it should be ok. Risco_Agility_User_Manual.pdf Heres a link I found that matches my manual dated 2012, the previous one is 2009: https://irp-cdn.multiscreensite.com/a1d869e9/files/uploaded/Agility-2-Full-User-Manual-UK1.pdf Edited October 23, 20188 yr by SeanT Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/page/2/#findComment-480187 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 26, 20197 yr comment_489177 Hello guys, I have a Risco Agility 3 with IP and GSM - both comms working fine. I have defined two Follow Me (FM), 1 = Me via SMS and 2 = The Wife via SMS also. I as FM1 get all SMS for events defined no probs. However, FM2 (i.e. The wifes phone) does not get anything - her phone is defined correctly - FM test successful (she gets a text) and she can set/unset via sms no probs. Is this by design perhaps, that the system tries the FM numbers in order and if FM1 IS successful, i.e. a SMS was sent ok to FM1 THEN IT IGNORES ALL OTHER DEFINED FMs? If so then it's a bit silly, as we would both like to get SMS for all events defined. Any thought and ideas will be appreciated. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/42420-hello/page/2/#findComment-489177 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
