Hello
22 minutes ago, SeanT said:
Yes you can, I used m2m (machine 2 machine) they ensure you sim will never expire
Ah great thanks - I was looking at a global m2m sim too - may try the gifgaff first and see how well that works.
  • Replies 21
  • Views 6.9k
  • I think you’re using the wrong commands to set and unset your alarm, you should be using S to set and US to unset so if your code is 1234 then you would use 1234 S to set and 1234 US to unset (I don’t
  • Glad it worked, I think its just P for part set, have a look at the list below:     I'll see if i can find a link to the update manual for you
  • There are various versions of the user manual that have slightly different commands, such as A and H for arming and disarming (as you found out). The manual I have uploaded is as close to my original
13 minutes ago, SeanT said:
ok, I think you need to go into engineers menu using * 0132
 Then go into programming #
Then system #
then controls #
the communications #
Fm enable half unlock symbol (y/n)
Cool thanks for that - I’ll try that later.
I also want my cloud connection to use IP first / then GPRS if IP not available - I saw the setting for that in: Programming > Communication > Cloud
Can’t really comment on that as I don’t have my system set up like that but hope it works
Just put my SIM in today - added all the FM numbers - did an FM test from the user menu too, FM test basically called my mobile number..
I have a question about arming, I know the GSM is working as it is giving me a status message by text, however when I do an ARM or HOME ARM command:
1234 A
OR
1234 H
It does nothing, No message from panel - checked panel still showing Ready and I did "1234 ST" for status message - got SMS from GSM module that the system is Ready.
Does your SMS arming work? Did you have to do anything else?
Thanks
I think you’re using the wrong commands to set and unset your alarm, you should be using S to set and US to unset so if your code is 1234 then you would use 1234 S to set and 1234 US to unset (I don’t think it’s case sensitive and you can omit the space if you want to). There is a list of commands in the user manual.
Hope this help
Hope this help
That is awesome mate - just tried your commands and they work - S for SET and US for UNSET  :)
Do you know the command for Part Set - I assume 1234 PS?
I am looking at my manual dated June 2013 which informs us to use A FOR ARM, H FOR PART ARM, D FOR DISARM....which is obviously incorrect... Do you know where I can get the latest User Manual from?
Thanks
Edited by MaxX
There are various versions of the user manual that have slightly different commands, such as A and H for arming and disarming (as you found out). The manual I have uploaded is as close to my original paper copy as I could find, however, it is slightly different but for most things it should be ok.
Risco_Agility_User_Manual.pdf
Heres a link I found that matches my manual dated 2012, the previous one is 2009:
https://irp-cdn.multiscreensite.com/a1d869e9/files/uploaded/Agility-2-Full-User-Manual-UK1.pdf
Edited by SeanT
  • 11 months later...
Hello guys,
I have a Risco Agility 3 with IP and GSM - both comms working fine.
I have defined two Follow Me (FM), 1 = Me via SMS and 2 = The Wife via SMS also.
I as FM1 get all SMS for events defined no probs.
However, FM2 (i.e. The wifes phone) does not get anything - her phone is defined correctly - FM test successful (she gets a text) and she can set/unset via sms no probs.
Is this by design perhaps, that the system tries the FM numbers in order and if FM1 IS successful, i.e. a SMS was sent ok to FM1 THEN IT IGNORES ALL OTHER DEFINED FMs?
If so then it's a bit silly, as we would both like to get SMS for all events defined.
Any thought and ideas will be appreciated.
