Pyronix Arming
Painter struck a viper, which then blew a fuse on an Enforcer.  Replaced the fuse however each time a user code is entered the panel says its testing before successfully arming.
Is there a way to reset this?
Any suggestions are welcome!
Ok be serious ( excuse the lingo nothing aimed at you)
Sounds like nonsense , something loose inside shorted the power?
What's the setup any pictures of what's inside the panel ?
Have you tried powering down whole panel , disconnect mains and disconnect battery in panel and restart?
Or you meant painter struck viper with brush full of water because he washing it and it went flying towards the viper
Come on we ain't got all day get typing man or woman
Thanks al-yeti,
Didn't know how much detail to put in the post.  The painter broke the cover and pulled out the power wires, and tamper, which as you said blew the fuse.
I have not powered the panel down completely so I will try that.  I thought this may be a programming parameter!
Will let you know.
10 minutes ago, jmac said:
Thanks al-yeti,
Will let you know.
Sounds like lunatic to me, you sure he's not an alarm man? Doing painting on the side ?
