Texecom premier Elite 48 - Night time setting
Hi All,
I've just installed a Texecom premier elite 48 with ricochet expansion.
System is up and running perfectly for full coverage but there seems to be a number of ways to programme "bed time".
Currently my system is all PIR's with a keypad in the hall.
PIR's are all set to guard currently. Upstairs is set to area B, downstairs to area A. Arm suite 1 (Bedtime) is all of down stairs but will include Garage and Shed eventually. Arm Suite 1 also sets silently which is good as we have a small person in the house.
So the error state that I've found is that as soon as I come down stairs the alarm is sounds instantly. Would setting the hallway to Guard Access cure this? And is the time delay set using the Entry 2 delay? Default is 45 seconds but I could be upstairs before the alarm has even sounded.
Thank you Sir!!!,
I'll get on the case with Wintex shortly.
Have I got the right end of the stick with the Guard Access and Delay 2?
