petrolhead Posted April 12, 2017 Share Posted April 12, 2017 Just flicking between the inputs at set intervals? It'll look ****, die to the time the hdmi handshake takes. Get a hybrid or an 8 channel nvr and use the anslogue dvr as an encoder, or get a cheap sff pc like a sumvision cyclone and install ivms4200 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41152-cctv-output-switching-question/page/2/#findComment-461746 Share on other sites More sharing options...
sharkey Posted June 26, 2017 Author Share Posted June 26, 2017 On 4/12/2017 at 7:30 PM, petrolhead said: Just flicking between the inputs at set intervals? It'll look ****, die to the time the hdmi handshake takes. Get a hybrid or an 8 channel nvr and use the anslogue dvr as an encoder, or get a cheap sff pc like a sumvision cyclone and install ivms4200 Cheers, Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41152-cctv-output-switching-question/page/2/#findComment-464869 Share on other sites More sharing options...
JohnnyFish Posted June 29, 2017 Share Posted June 29, 2017 I've had some crazy requests in my time but this one sounds mental! You could maybe try pip depending on the tv but obviously one would have to be via bnc output, and it'll only be a small box in the corner of the screen. other option could be to use the ivms software, again depending on the tv (android etc) and whether or not they're on your network? All streams could then be added to one screen... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41152-cctv-output-switching-question/page/2/#findComment-465085 Share on other sites More sharing options...
