sperth Posted March 22, 2017 Share Posted March 22, 2017 Hi, I would like to find out how to delete the Sim Pin Code using a Risco Lightsys2 Panel? None of the keys on the panel actually remove the entered pin code Thanks! Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 22, 2017 Share Posted March 22, 2017 Can you not put it i to a phone first and remove or disable the pin? Even if it's a size difference you can use an adapter after Quote Link to comment Share on other sites More sharing options...
sperth Posted March 22, 2017 Author Share Posted March 22, 2017 Hi, Sorry I should have described the issue more clearly. I have entered the Sim pin code in the panel. I have checked that the sim pin is disable on a phone. But on the panel I can't seem to delete the pin code. I can scroll left or right and the cursor moves, but I cannot blank it out. Hope this description helps Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 22, 2017 Share Posted March 22, 2017 In manual it should say what to enter to make it blank, what if you leave it blank and press yes or enter whatever it says Quote Link to comment Share on other sites More sharing options...
sperth Posted March 22, 2017 Author Share Posted March 22, 2017 I've currently set it to '0000'. The manual doesn't show to how make it blank. Not sure what I can do to leave it blank. Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted March 22, 2017 Share Posted March 22, 2017 I don't know the panel but if the SIM PIN is set Disabled there will be no PIN, so I don't know why the PIN code menu would be enabled. Quote Link to comment Share on other sites More sharing options...
