galaxy 'set' input
Does the galaxy G3 have a zone type similar to the keyswitch zone type where it only sets the system when the keyswitch zone is open? I need to be able to set a G3 from a panel in another building but the keyswitch zone type isn't ideal as it would also unset it when the main building is unset. Any ideas on if I can use the keyswitch zone type or if I should be using a custom zone? cheers
set the input keyswitch and pulse type (enable the * modifier), then just use the switch dc output type on the source panel it will only then arm the other system not disarm
press * when selecting the zone type
