Apollo 65 SD on Galaxy
On 14 January 2017 at 5:31 PM, Simlec said:
You will not be saying that if they save your life one day!!
HKC ones are not that bad.. I'm sure they would also save my life
  • 3 weeks later...
  • Replies 73
  • Views 18.1k
  • Each battery powered smoke alarm has its own sounder, should it detect a fire it makes a noise   A 12v intruder alarm has the sounder separate from the detection device, combustible cables m
  • Shaunb1905
    Shaunb1905
    Must be mental using twinflex!!
  • grade D can be connected to their own dedicated circuit or a regularly used lighting circuit   my preference is with the lights, more so because if there is a fault its usually noticed soone
On 7 January 2017 at 9:38 PM, norman said:
I have 3 wired co and 2 radio heat/smokes.
Is this off a galaxy panel?
22 hours ago, norman said:
Yes
I'm going for a similar set up to yourself.. just wired in a RF portal, want to put a radio device on that as well as have a separate AICO base wired.
