pjm1959 Posted June 5, 2016 Share Posted June 5, 2016 Hi folks Am doing a self install on a new build house and need some help on a few things if you don't mind. I have the following: Accenta mini gen 4 AD-01 Auto dialler AG6 External sounder & strobe. 1) How do I wire the Auto dialler into the gen 4? Terminals on Auto dialler are: Tamp (x2), TR2, TR1, 0v & 12v+. Think these wires should go to Panel J3 on the gen 4 and the terminals are +13v, 0v, Fire, PA,INT, SET & ABORT? 2) How do I wire the External strobe into the gen 4? Terminals on strobe are: ST- (strobe trigger), R- (Tamper return), SW- (Sounder trigger), V+ (positive supply & V (negative supply. Think these wires should go to Panel J6 on the gen 4 and the terminals are : + strobe, - strobe, T (scb), A (scb), D (bell), B (bell) & set. Thanks in advance Peter Quote Link to comment Share on other sites More sharing options...
pjm1959 Posted June 11, 2016 Author Share Posted June 11, 2016 Anyone?? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted June 11, 2016 Share Posted June 11, 2016 (edited) For the dialler Connect the +13v To + - 0v to - B to tr1 (b Aslong as it's the negative bell trigger) This is simplest way D BELL is the plus + hold off so don't get confused by that or AMP lol Edited June 11, 2016 by al-yeti 1 Quote Link to comment Share on other sites More sharing options...
al-yeti Posted June 11, 2016 Share Posted June 11, 2016 (edited) For the bell Generally ( I having a snooze) R Tamper return to T Dbell to v + 0v to v - -bell to - sw - strobe to - Don't use +strobe if it's there Edited June 11, 2016 by al-yeti 1 Quote Link to comment Share on other sites More sharing options...
