bennynoneck Posted September 9, 2015 Author Share Posted September 9, 2015 Fan-bloody-tastic!!!! So the 2 tamper wires are now out of the window! The 4 zone wires are obvious. That just leaves the 2x power wires. I'll wire these in parallel at the PIR terminals to join the PIRs together, and at the control panel I'll just the join the two red togther and the two black together in the control panel terminals. So nothing is in series. I only need to join the zone 2 cables to the next stretch of cable to get to the second PIR. For this i'll use a terminal strip. I guess 3amp is more than fine, considering the whole unit is fused by 3 amps! Many thanks. Yes i saw the dot as meaning it not being supported. But i only glanced. Quote Link to comment Share on other sites More sharing options...
mountianrider Posted September 27, 2015 Share Posted September 27, 2015 why dont you wire it eol? Quote Link to comment Share on other sites More sharing options...
