frenchman Posted August 6, 2015 Share Posted August 6, 2015 Hi, using Ivms 4200 from Hik, the client get a " abnormal recording" windows popping up at random . Footage is there and exploitable but this message seems to come back every now and then. Any ideas? Also on the app, it appears that they can only access around 3 days of footage at a time, sometimes not the most recent three days? NVR is a 7600 series with 4 ds2112. have any of you wise old owls got any knowledge you'd like to share with a fellow installer/ Merci bien. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38899-hikvision-minor-issues/ Share on other sites More sharing options...
charlie6 Posted August 6, 2015 Share Posted August 6, 2015 How old is it..when was it installed ? sounds like a program issue. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38899-hikvision-minor-issues/#findComment-426480 Share on other sites More sharing options...
frenchman Posted August 11, 2015 Author Share Posted August 11, 2015 Hi charlie6, installed around 2 months ago, tech support are not sure what it could be Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38899-hikvision-minor-issues/#findComment-426798 Share on other sites More sharing options...
charlie6 Posted August 11, 2015 Share Posted August 11, 2015 I'm not regarded as the 'main runner' in this field, but I would guess (working on lower end equipment) that you have a faulty device, disconnect to only the bare minimum and test again. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38899-hikvision-minor-issues/#findComment-426804 Share on other sites More sharing options...
cctvtech Posted September 29, 2015 Share Posted September 29, 2015 You could try to re-install the driver. Alternatively, try to contact Hikvision http://www.hikvision.com/europe/contactHikvision.asp Hope you get it sorted! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38899-hikvision-minor-issues/#findComment-431521 Share on other sites More sharing options...
