robl2821 Posted April 26, 2015 Share Posted April 26, 2015 Hi all, I'm probably being really dim and missing something really obvious but any help appreciated. I've installed a Premier Elite 24, simple system, one kepad, 6 contacts. Programming using Wintex. I've set up area A as all devices for a simple full set. I was looking to use area B as a night mode which would inlcude 4 of the circuits, just on the ground to allow people to move around upstairs. I've been through the zone set up and ticked area B on those I wish to include and created a seperate user code just for area B as a 'night pin'. I've also made sure the keypad is ticked for both areas. Under the 'Area' tab, under areas, Area B is set to 'Entry/Exit' and under 'Area Arm Suites' to timed exit. When I set area B it countdown and shows part armed etc, but the system then doesn't re-act when any of the doors are opened. If I change one of the circuits so it's just on area B it then works. Is this a limitation of the panel and circuits can only be assigned to one area or have I ballsed up somewhere? Thanks Rob Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38435-area-set-up-on-texecom-premier-elite-24/ Share on other sites More sharing options...
sixwheeledbeast Posted April 26, 2015 Share Posted April 26, 2015 You should use the part set option for this not the Areas Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38435-area-set-up-on-texecom-premier-elite-24/#findComment-416671 Share on other sites More sharing options...
robl2821 Posted April 26, 2015 Author Share Posted April 26, 2015 Thanks, will try when I'm back on site tomorrow. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38435-area-set-up-on-texecom-premier-elite-24/#findComment-416673 Share on other sites More sharing options...
lamplight73 Posted May 20, 2015 Share Posted May 20, 2015 There is an answer on the Texecom website, something to do with you have to assign the ccts to both areas. I've a similar problem. I need a final door set on full set, silent set on night part arm but timed, and then another part arm but as in full set but without a particular cct. Mind f@ck. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38435-area-set-up-on-texecom-premier-elite-24/#findComment-418749 Share on other sites More sharing options...
breff Posted May 21, 2015 Share Posted May 21, 2015 Piece of pi55, do NOT use multiple areas, assign all zones to area A then use the part omit options, tell it what zones you want off in what part set. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/38435-area-set-up-on-texecom-premier-elite-24/#findComment-418764 Share on other sites More sharing options...
