9651 Posted January 12, 2015 Share Posted January 12, 2015 (edited) yes, you could do that. just connect the bell op of the Garage system to drive a clean contact relay and connect that into the house veritas zone. Prog that as PA, then connect PA upto the dialler, put the message into it as garage. Job done. But for all that ******* about i'd stick a Premier Elite 24 poly in, set it up with areas. Thats will do everything you need and be proper....... Edited January 12, 2015 by 9651 Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted January 12, 2015 Share Posted January 12, 2015 (edited) As above at least that way if it ever goes off in the night you dont have to go out the house to turn it off and get bopped over the head by billy the burglar... Edited January 12, 2015 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
