Carl Prime Posted June 4, 2014 Share Posted June 4, 2014 Hi guys I have a Varitas R8 and am attempting to wire an autodailer to the system ive wired it as v+ and v- to the communicator output on the main panel and linked v+ to contact 3 on the dailer but when i test to see if it calls out on activation I can't seem to get it to work. But when you set the system it calls out. Also I didn't know if it was best to connect the 3 to the bell output from the main panel as it does say R8 is a v- switch. Helllllp its doing my nut in. How should it be wired? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/36815-texecom-autodailer/ Share on other sites More sharing options...
Rulland Posted June 4, 2014 Share Posted June 4, 2014 Connect output three (intruder) on the communicator to input three(usually used for intruder) on the dialler. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/36815-texecom-autodailer/#findComment-383889 Share on other sites More sharing options...
secureiam Posted June 4, 2014 Share Posted June 4, 2014 If its an R8 rather than an R8+ then he needs to connect to the bell trigger as the communicator outputs are only on the R8+ and Excel panels. The +ve and -ve from the panel go to the +ve and -ve on the dialler, then its bell trigger or communicatotor output 3 to the the dialler. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/36815-texecom-autodailer/#findComment-383910 Share on other sites More sharing options...
Rulland Posted June 4, 2014 Share Posted June 4, 2014 One assumed, from his OP, that he had an R8+ not an R8, as he stated he'd taken +ve and -ve from the communicator interface. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/36815-texecom-autodailer/#findComment-383914 Share on other sites More sharing options...
secureiam Posted June 4, 2014 Share Posted June 4, 2014 Yeah i thought that when I first read it, in fact read it about three times and wasnt 100% sure afterwards what was going on. V+ to contact 3??, . He probably has an R8+ and got a little confused reading the installation manual, as I don't get the connection hes tried. OR Hes thought theres a communicator on the panel but not connected to the output because it actually doesnt have a terminal block as would be the case on the R8. So trying to cover the last possability just in case. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/36815-texecom-autodailer/#findComment-383921 Share on other sites More sharing options...
al-yeti Posted June 8, 2014 Share Posted June 8, 2014 Only issue with the texeco m dialled if for any reason bell signal drops it will stop dialling so better to connect to something that will only reset with code or tag, ie strobe or another intruder output , I suppose its only if it didn't get hold of anyone within the bell time but I found it better to avoid the bell output with this dialler if it's set to code Or reset to stop signalling , or its another dialled your talking about Link to comment https://www.thesecurityinstaller.co.uk/community/topic/36815-texecom-autodailer/#findComment-384624 Share on other sites More sharing options...
secureiam Posted June 8, 2014 Share Posted June 8, 2014 You can change how the Texecom dialler responds, at default its code or restore, but you can change it to retore only or code only or nothing. On Nothing once its started the process it wont stop, even if the trigger has been restored until ts gone through the motions, you can get it to dial everyone, by changing the acknowledgement type. Acknowledge only, will stop calling the person that has acknowledged the call and dial the next in the list when the call is ackwnoledged (texts are automatically acknowledged), Stop calls will stop the system from dialling anyone else once a call has been acknowledged by anyone in the system. I think its better to have it on nothing and stop calls (unless using text), so that someone that acknowledges the call is the one that deals with the problem and it doesnt dial anyone else and it doesn't matter if the bell timer is on for a short time. Depends on what you can do easily at the panel end I guess, but the dialler is very flexible. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/36815-texecom-autodailer/#findComment-384645 Share on other sites More sharing options...
