Theenemy85 Posted April 24, 2014 Share Posted April 24, 2014 Hi, I installed a Galaxy G2+44 panel today and have just realised I forgot to install the 680Ω EOL resistor across the data line in the last Keyprox. I programmed it and everything was working fine when I left. Does anyone know how likely is it to cause me problem/callouts? Thanks Link to comment Share on other sites More sharing options...
matthew.brough Posted April 24, 2014 Share Posted April 24, 2014 Depends. It is there for a reason. If passing the site I'd be inclined to pop it in. www.securitywarehouse.co.uk/catalog/ Link to comment Share on other sites More sharing options...
Theenemy85 Posted April 24, 2014 Author Share Posted April 24, 2014 Hi Matthew Thanks for your reply. What do you mean it depends? I'm not likely to be passing the site anytime soon but could make a special trip if it's likely to cause problems Link to comment Share on other sites More sharing options...
goncall Posted April 24, 2014 Share Posted April 24, 2014 it won't cause any problems Link to comment Share on other sites More sharing options...
matthew.brough Posted April 24, 2014 Share Posted April 24, 2014 Chances are you'll get away with it. As it is a rs485 like it should be balanced and as the eol is missing it's not but unless you get a call saying the panel is showing missing modules chances are if it's a small run dataline you'll probably get away with it. it won't cause any problemsThat isn't a guarantee although on a g2 I'd think it highly likely that he'll get away with it but to say its a dead cert would be wrong. It's there for a reason. If it wasn't necessary Honeywell wouldn't ship them with the panel. www.securitywarehouse.co.uk/catalog/ Link to comment Share on other sites More sharing options...
goncall Posted April 24, 2014 Share Posted April 24, 2014 Chances are you'll get away with it. As it is a rs485 like it should be balanced and as the eol is missing it's not but unless you get a call saying the panel is showing missing modules chances are if it's a small run dataline you'll probably get away with it. That isn't a guarantee although on a g2 I'd think it highly likely that he'll get away with it but to say its a dead cert would be wrong. It's there for a reason. If it wasn't necessary Honeywell wouldn't ship them with the panel. I've seen gals wired in 8 core on long runs spurred off etc they give less data problems than belden be it with eols in the mods or not,either way if your gonna get a problem your gonna get a problem so in this case I wouldn't be rushing back to fit it Link to comment Share on other sites More sharing options...
matthew.brough Posted April 24, 2014 Share Posted April 24, 2014 Clearly you understand nothing about rs485 www.securitywarehouse.co.uk/catalog/ Link to comment Share on other sites More sharing options...
goncall Posted April 24, 2014 Share Posted April 24, 2014 Clearly you understand nothing about rs485 call it experience.. Link to comment Share on other sites More sharing options...
matthew.brough Posted April 24, 2014 Share Posted April 24, 2014 Irrelevant. Don't take my word for it. Use your friend google. Termination is there for a reason. www.securitywarehouse.co.uk/catalog/ Link to comment Share on other sites More sharing options...
goncall Posted April 24, 2014 Share Posted April 24, 2014 Irrelevant. Don't take my word for it. Use your friend google. Termination is there for a reason. I never said it wasn't but in my experience I've seen all ways a line has been wired and all wrong and they sit happy,I've seen perfect runs in belden all terminated and problems,so in this case as the op posted I'd just wait till the next visit to fit the 680 as unlikely to be a problem which was the question,now go and play with your white elephant Link to comment Share on other sites More sharing options...
