Adi Posted April 3, 2011 Share Posted April 3, 2011 is it just ACT that do them? I really can't be ar**** with it anymore. Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted April 3, 2011 Share Posted April 3, 2011 is it just ACT that do them? Pretty much. What about the test key and have an extended lunch tester? Link to comment Share on other sites More sharing options...
Adi Posted April 3, 2011 Author Share Posted April 3, 2011 want for general testing. Took over a new site, 3ft flourescent wont work, swapped batt, has voltage but still wouldnt come on, was going to test that batt was charging but i blew me fuse in the meter the other day and i couldne be arsed to go back to the van to put new fuses in. Thought today if i had a batt tester, i could prove battery one way or the other. If battery ok, i'd put it down to control gear. But at £175 ish, i'll think i'll do without. PLus some of the test switches/normal switches in each apartment are wired back to front and upside down and all sorts. I really can't be ar**** with it anymore. Link to comment Share on other sites More sharing options...
