Opening Ports On Bt Business Hub
alterEGO
I'm haveing some problems with ports on a BT Business hub, they are all showing as open on the router firewall page, but when i check the ports on ping.eu they are all showing closed!!!!!!!
Any help would be good. I've done other BT routers (older versions) and netgear etc with no problems, just can't see the issue with this one????
cheers
post-13291-092985600 1284732112_thumb.jp
2wire 121 hub, judging by screen print? Ours blew up couple of months back so legged it up to pc world fitted netgear & up running hour or so later.
bt sent new hub couple of days later (twas over w/end) & still on side of desk waiting to be swapped out.
Yep, all working now.
My next task is to try and get a DYNDNS up and running, i'm lazy and ALWAYS get the customer to get a static IP.
