Amps Posted May 26, 2009 Share Posted May 26, 2009 Is there more than one data line on a galaxy 96 ? If there is only one, is it still possibly to connect two lines if an onboard resistor is cut? I know this was possible on a galaxy 60 but have no idea about the new stuff. Ta. Link to comment Share on other sites More sharing options...
Guest old-hand Posted May 26, 2009 Share Posted May 26, 2009 Two lines on a 96. I take it you want to fit two keypads at each end of a property. For your info GD48 1 line GD96 2 lines GD264 2 lines GD520 4 lines Link to comment Share on other sites More sharing options...
Amps Posted May 26, 2009 Author Share Posted May 26, 2009 Two lines on a 96.I take it you want to fit two keypads at each end of a property. For your info GD48 1 line GD96 2 lines GD264 2 lines GD520 4 lines Existing galaxy 48 that is wired with two data runs, i'm not up to date with galaxy and couldn't figure out where/which/if resistor needs cutting like with the old galaxy 60. Two lines on the 96 you say so thats problem solved, nice one : Link to comment Share on other sites More sharing options...
Amps Posted May 27, 2009 Author Share Posted May 27, 2009 Changed the 48 for the 96 today, do i take it that the aux. tamp terminal is for the negative bell tamper return? If so i couldn't get the panel to trigger with a negative return removed. Any ideas/pointers ? Also as i now have a "free" Galaxy 48 to play with i'm thinking of uprading my house alarm Abacus 6 LCD and i'd like to set the Galaxy up for remote access, is it possibly to get free Galaxy Gold software anywhere ? Link to comment Share on other sites More sharing options...
Guest old-hand Posted May 27, 2009 Share Posted May 27, 2009 LOL @ free Gold. When testing the tamper return on the bell were you still in engineering by any chance?. Link to comment Share on other sites More sharing options...
Amps Posted May 27, 2009 Author Share Posted May 27, 2009 LOL @ free Gold. When testing the tamper return on the bell were you still in engineering by any chance?. Never got chance to test in day mode mate i just thought the fault aux. tamper would show with the rio tamper faults when i tried to exit engineers mode. Will give it a go tomorrow. Clicked on you "free Gold" link but doesn't seem to work Link to comment Share on other sites More sharing options...
Guest old-hand Posted May 27, 2009 Share Posted May 27, 2009 Never got chance to test in day mode mate i just thought the fault aux. tamper would show with the rio tamper faults when i tried to exit engineers mode. Will give it a go tomorrow. Should have TBH. You are running the GRD to AUX tamper for the -ve return? Try it with the RIO`s closed and lid tamper closed too to prove the point. Link to comment Share on other sites More sharing options...
gken74 Posted May 28, 2009 Share Posted May 28, 2009 Is there more than one data line on a galaxy 96 ? If there is only one, is it still possibly to connect two lines if an onboard resistor is cut? I know this was possible on a galaxy 60 but have no idea about the new stuff. Ta. On the GD96 you've got 2 jumpers LK3 & LK5 behind the 485 bus which have replaced the onboard resistors which you'd cut in the G60 so you could run the data cable in 2 directions from one data line. Link to comment Share on other sites More sharing options...
SouthernBrad Posted July 9, 2010 Share Posted July 9, 2010 On the GD96 you've got 2 jumpers LK3 & LK5 behind the 485 bus which have replaced the onboard resistors which you'd cut in the G60 so you could run the data cable in 2 directions from one data line. Beat me to it i was going to mention you could have just used a new 48 Panle over the 96.Remove link 3 on the 48. Link to comment Share on other sites More sharing options...
Rulland Posted July 9, 2010 Share Posted July 9, 2010 Beat me to it i was going to mention you could have just used a new 48 Panle over the 96.Remove link 3 on the 48. Only just!-last post was a year ago lol Link to comment Share on other sites More sharing options...
