james.wilson Posted June 20, 2008 Share Posted June 20, 2008 This started life a while ago, has had various versions. This is a current version we use for various things. Please feel free to use it. I will try to just post the compressed exe, if this fails i will post the full setup program. Needs microsoft.net 2.0 installed on your machine if your machine is patched and upto date it will work fine if not download .net 2 from microsoft (via windows update) Screenshots Below Sceenshot 1 = Battery Standby Time Calcs Select day and Alarm currents, Intruder grade or fire alarm, select if reporting ac fail to arc. Press Calculate, and below will calc minimum battery size required. Screenshot 2 = Volt drop calcs Select Cable type, number of cores used, distance in meteres and Total load over section. Press calculate and it will show voltage drop. Currenyly only supports Alarm cable, more can be added by request. Screenshot 3 = CCTV Lens Calculator Select format, then fill in the 2 knows, ie distance and secen width. Press the calculate button required to fill in the missing details. Screenshot 4 = HD disk Just for the dm Digi sprite, again more can be added but will need to know the data of the machine. Screenshot 5 = IP camera bandwidth / storage calc. We use axis cams so only written for them, but uses jpg as its basis so should work for any jpeg camera. Screenshot 6 and 7 = Misc and currently Serial Printer. This is for using you laptop as a serial printer. Assumes normal baud rate and if used i will add a settings option to chnage com port etc. Basically use a null modem lead to connect to you panel, Press serial printer, then print the details required. Once finished press convert (this will lay it out nicely) then press save, and you can save the printer output as a text file. Screenshot 8 = Sounder volume calcs, was designed for fire but will calculate sound pressure loss over a distance. Based on the fulleon specs. Saves using those charts. Enter distance in meters, Sound pressure output of sounder, select if that reading is recorded at 1m or 3m, then press calculate, tool will show SPL at selected distance. Let me know. James techmaster.zip securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Joe Harris Posted June 23, 2008 Share Posted June 23, 2008 Seems a useful compilation of several tools I have spread about as applets or web links on my pc at the moment - it is much more useful to have them compiled though. Thank you for sharing it and I will let you know how I get on with it. 'J Link to comment Share on other sites More sharing options...
macwillis Posted November 9, 2008 Share Posted November 9, 2008 any chance of making that into a excel document,. i have a mac and cant open the .exe -Willis- Link to comment Share on other sites More sharing options...
Gopher Posted November 10, 2008 Share Posted November 10, 2008 any chance of making that into a excel document,.i have a mac and cant open the .exe It's a Windows only program would need to be redone to work on a MAC so it could be package properly to install on a MAC. Intruder / CCTV / Access Control Technical Support Personal Subscriber to the "K.I.S.S" principle, that's Keep It Simple Stupid, are you? Link to comment Share on other sites More sharing options...
macwillis Posted November 10, 2008 Share Posted November 10, 2008 dont want it as an app on OSX just as a EXCEL document. .xls -Willis- Link to comment Share on other sites More sharing options...
james.wilson Posted November 10, 2008 Author Share Posted November 10, 2008 maybe, but for us the need is the application. We also released it here. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Omega Posted November 11, 2008 Share Posted November 11, 2008 What a cracking series of applications..............especially the lense calculator Regards Link to comment Share on other sites More sharing options...
macwillis Posted November 11, 2008 Share Posted November 11, 2008 okay, i think ill work on the .xls myself. (hunts for his XP disk) -Willis- Link to comment Share on other sites More sharing options...
a1steve Posted November 24, 2008 Share Posted November 24, 2008 okay, i think ill work on the .xls myself. (hunts for his XP disk) how do i get the printer bit to work on a galaxy panal? Link to comment Share on other sites More sharing options...
james.wilson Posted November 24, 2008 Author Share Posted November 24, 2008 you need a 232 or printer insterface on the gal, then connect that to com1 on the pc via a null modem and thats it. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
