stress3 Posted September 13, 2007 Share Posted September 13, 2007 Hello There ! Just wondering if any of you guys could advise me on minimum T&E from an unswitched fuse spur, as on my C&G course 3 years ago they told us sizes, and then i had one of these i know every thing inspectorates come round and inform me that my sizes were wrong, i then ask a qualified spark and he told me it was o.k i searched through IEE wire regs and onsite guide and could not find what he was chatting about. So if any one could answer this i would very grateful !!!!! Q. Minimum size T&E from an unswitched fuse spur and were to find in Black & White ? Thanks Stress3 Link to comment Share on other sites More sharing options...
Guest anguscanplay Posted September 13, 2007 Share Posted September 13, 2007 Hello There ! Just wondering if any of you guys could advise me on minimum T&E from an unswitched fuse spur, as on my C&G course 3 years ago they told us sizes, and then i had one of these i know every thing inspectorates come round and inform me that my sizes were wrong, i then ask a qualified spark and he told me it was o.k i searched through IEE wire regs and onsite guide and could not find what he was chatting about. So if any one could answer this i would very grateful !!!!! Q. Minimum size T&E from an unswitched fuse spur and were to find in Black & White ? Thanks Stress3 what panel and what size were you using ? Link to comment Share on other sites More sharing options...
stress3 Posted September 13, 2007 Author Share Posted September 13, 2007 Hi angus ! It was for a 2amp psu supplying one door controller ! and it was 2.5mm ! Link to comment Share on other sites More sharing options...
Guest anguscanplay Posted September 13, 2007 Share Posted September 13, 2007 Hi angus !It was for a 2amp psu supplying one door controller ! and it was 2.5mm ! assuming it wasnt spurred of anything bigger that would be plenty big enough - cant think where to prove it though , one of the sparks will be along soon ( I know but we have to humour them ) to quote bs , en , iee whatever Link to comment Share on other sites More sharing options...
stress3 Posted September 13, 2007 Author Share Posted September 13, 2007 I thought it would o.k ! it was only spured from a double outlet socket from a ring main ! when he said wrong size i could only think he was thinking it was 1.5mm ! but then i asked that question to a spark and he said even that would be ok because the load would not be compramising that integraty of the cable. So I am a little confused and sometimes i like to see things in writing and hear other peoples views ! before taking 1 mans opinion ! I once read that Regs were the obedience of blind fools and the guidance of wise Men ! Stress3 Link to comment Share on other sites More sharing options...
Guest Dave the alarm man Posted September 13, 2007 Share Posted September 13, 2007 Just wondering if any of you guys could advise me on minimum T&E from an unswitched fuse spur, 1mm2* Minimum size T&E from an unswitched fuse spur and were to find in Black & White ? loadings for thermoplastic cables is on the charts in 7671 * in some but not all cases Link to comment Share on other sites More sharing options...
tinnitus Posted September 13, 2007 Share Posted September 13, 2007 im 99% sure you have to use flex, T&E wont comply to anything. Link to comment Share on other sites More sharing options...
Guest Dave the alarm man Posted September 13, 2007 Share Posted September 13, 2007 im 99% sure you have to use flex, T&E wont comply to anything. well depends on how cable enters enclosure, flex = compression gland exiting spur thorugh flex outlet t&e = glanded hole exiting spur through pattress / boack box TBH most mix & match on this, also you could if you really wanted to, you could install all the fixed wiring in flex just the shower & cooker circuit would be the problem as you can't get flex in that size Link to comment Share on other sites More sharing options...
stress3 Posted September 13, 2007 Author Share Posted September 13, 2007 Surely Not FLEX from a double gang socket to the spur !! T&E from Double gang to spur is what I was pulled up on ! Link to comment Share on other sites More sharing options...
Guest anguscanplay Posted September 13, 2007 Share Posted September 13, 2007 Surely Not FLEX from a double gang socket to the spur !!T&E from Double gang to spur is what I was pulled up on ! just double check it wasnt 4mm then - if its 2.5mm then all of us would go 2.5mm T+E to spur ( or fcu as they like to call em nowadays ) and then 1mm flex or T+E to the panel - we cant all be wrong you sure it was the correct colored cable ? Link to comment Share on other sites More sharing options...
