cjay Posted June 30, 2007 Share Posted June 30, 2007 Hello, I've never installed a PIR in a bathroom before. Has anyone had any experience of this? Is it advisable or not? Link to comment Share on other sites More sharing options...
Guest Dave the alarm man Posted June 30, 2007 Share Posted June 30, 2007 wet room, no Link to comment Share on other sites More sharing options...
camerabloke Posted June 30, 2007 Share Posted June 30, 2007 redwall? Eucam Security Systems 0845 4630 746 www.eucam.co.uk Link to comment Share on other sites More sharing options...
alterEGO Posted June 30, 2007 Share Posted June 30, 2007 Hello,I've never installed a PIR in a bathroom before. Has anyone had any experience of this? Is it advisable or not? IMO, No. due to steam ect. fit a contact on the window. Link to comment Share on other sites More sharing options...
camerabloke Posted June 30, 2007 Share Posted June 30, 2007 will that not also corrode after time though? Eucam Security Systems 0845 4630 746 www.eucam.co.uk Link to comment Share on other sites More sharing options...
alterEGO Posted June 30, 2007 Share Posted June 30, 2007 will that not also corrode after time though? sealed contact clever clogs and even if it did, much better then a powered device due to fuses ect. and yes IP rated jb. Link to comment Share on other sites More sharing options...
camerabloke Posted June 30, 2007 Share Posted June 30, 2007 was gona say about the JB. Eucam Security Systems 0845 4630 746 www.eucam.co.uk Link to comment Share on other sites More sharing options...
Guest Dave the alarm man Posted June 30, 2007 Share Posted June 30, 2007 fit a contact on the window. wet room, no contact the internal door of the bathroom smc out side the room. ground floor bathroom? A 3 lever lock on the door (when out) may be an idea I assume like my bathroom there nowt worth nicking unless you've got that really posh bog roll? Link to comment Share on other sites More sharing options...
alterEGO Posted June 30, 2007 Share Posted June 30, 2007 wet room, nocontact the internal door of the bathroom smc out side the room. ground floor bathroom? A 3 lever lock on the door (when out) may be an idea I assume like my bathroom there nowt worth nicking unless you've got that really posh bog roll? it is fine to contact the window in the means i have described. if you contact the door what will they do at night? omit it and be unprotected? Link to comment Share on other sites More sharing options...
Guest Dave the alarm man Posted June 30, 2007 Share Posted June 30, 2007 if you contact the door what will they do at night? omit it and be unprotected? maybe, or tunstall zone omit module either on timer or controled by chubb lock it is fine to contact the window in the means i have described. sub curls one out or the mirror steams up so they open window what happens then smarty pants? Link to comment Share on other sites More sharing options...
