siqveland Posted March 1, 2007 Share Posted March 1, 2007 Hi, I hope this is not a silly question... I am planning to connect 2 x 12v piezo sirens to the powermax+ control panel in parallel to the internal alarm loop.. is that ok??? or should I connect them in series??? or should I not connect 2 sirens at all?? thanks in advance for your help Link to comment Share on other sites More sharing options...
arfur mo Posted March 1, 2007 Share Posted March 1, 2007 Hi,I hope this is not a silly question... I am planning to connect 2 x 12v piezo sirens to the powermax+ control panel in parallel to the internal alarm loop.. is that ok??? or should I connect them in series??? or should I not connect 2 sirens at all?? thanks in advance for your help hi siqveland, you would connect them in parrelel, not series if they are true sirens, only internal speakers would go in serie's and external self activating sirens. being piezo's devices they draw fairly low current, so no problem driving them from the external bell (SAB) output using + and - terminals. regs alan If you think education is difficult, try being stupid!!!! Link to comment Share on other sites More sharing options...
luggsey Posted March 1, 2007 Share Posted March 1, 2007 Hi,I hope this is not a silly question... I am planning to connect 2 x 12v piezo sirens to the powermax+ control panel in parallel to the internal alarm loop.. is that ok??? or should I connect them in series??? or should I not connect 2 sirens at all?? thanks in advance for your help Check the loading of two sirens, see if the loading is greater then the output you plan to use in the panel. You will need the instruction/engineer books to get this information. Also check that the "internal alarm loop" is a powered supply type and not a speaker output, again check the books. ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum Link to comment Share on other sites More sharing options...
siqveland Posted March 1, 2007 Author Share Posted March 1, 2007 Thank you very much for the help Link to comment Share on other sites More sharing options...
