john@total Posted November 9, 2006 Share Posted November 9, 2006 Has anyone fitted a DVR called DVR365 from suppliers SYSTEMQ? If so are they any good? Link to comment Share on other sites More sharing options...
Cubit Posted November 9, 2006 Share Posted November 9, 2006 Has anyone fitted a DVR called DVR365 from suppliers SYSTEMQ?If so are they any good? Yep Worked straight out of the box. Nothing spectacular, but des what i need it to. Andrew Link to comment Share on other sites More sharing options...
bellman Posted November 9, 2006 Share Posted November 9, 2006 Has anyone fitted a DVR called DVR365 from suppliers SYSTEMQ?If so are they any good? Got one installed here at home, cracking piece of kit, easy to use, reliable and a good suite of functions. It has lan, ptz control, several alarm in / out ports, usb port, vga port and a host of other features. SystemQ were most helpfull with advice and their tech support is second to none. I would have no hesitation in recommending one, or SystemQ. Also have a look at the video tardis, simlar functions in a slightly smaller case. Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer. Link to comment Share on other sites More sharing options...
dsw Posted November 10, 2006 Share Posted November 10, 2006 Very good DVR mate, have installed 3 or 4. Only issue i have with them is the remote control don't work to well and playback is lacking a few basic functions like frame by frame. A few customers have had trouble with the end user interface on playback. Not the easiest but still very good. Internet monitoring is one of the best ive seen, always get near real time images over decent broadband connection. Oh yes only other fiddly problem is you have to stop all recording, format HDD, and then start recording again just to change the clock. Bit of a pain really but don't let this put you off as nothing comes close for value for money. BTW don't forget to check the new cop dvr,similar price, similar spec and it's got talkback facility on it. Link to comment Share on other sites More sharing options...
bellman Posted November 10, 2006 Share Posted November 10, 2006 Oh yes only other fiddly problem is you have to stop all recording, format HDD, and then start recording again just to change the clock. I leave mine set to GMT saves all the messing about Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer. Link to comment Share on other sites More sharing options...
john@total Posted November 11, 2006 Author Share Posted November 11, 2006 Got one installed here at home, cracking piece of kit, easy to use, reliable and a good suite of functions. It has lan, ptz control, several alarm in / out ports, usb port, vga port and a host of other features. SystemQ were most helpfull with advice and their tech support is second to none.I would have no hesitation in recommending one, or SystemQ. Also have a look at the video tardis, simlar functions in a slightly smaller case. Regards Bellman thanks for all your advice i use LJD's colossus PRO's at the minute and there web access is quite good, but if there is better i might give them a try as i could have about 60 sites to link back to there head office. Link to comment Share on other sites More sharing options...
bellman Posted November 11, 2006 Share Posted November 11, 2006 Have a look at the demo site, HERE Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer. Link to comment Share on other sites More sharing options...
john@total Posted November 11, 2006 Author Share Posted November 11, 2006 Have a look at the demo site, HERERegards Bellman Hi is seems ok, demo only has cif res, not really good enough for my needs but that might be just the demo software but i dont think so. thanks all the same. john Link to comment Share on other sites More sharing options...
