hiro Posted October 17, 2006 Share Posted October 17, 2006 you've probably had this before but i've just changed to an adsl wireless router.its connected to my desk top via lan and laptop via wireless (both xp) I can access internet from laptop no bother but desktop just not having it Any comments or points i make are my own views and not that of my employer or company Link to comment Share on other sites More sharing options...
Guest Posted October 17, 2006 Share Posted October 17, 2006 you've probably had this before but i've just changed to an adsl wireless router.its connected to my desk top via lan and laptop via wireless (both xp) I can access internet from laptop no bother but desktop just not having it Check your fire wall settings. Your router prob works on 192.168.2.1 or 192.168.1.1. You need to program a range of IP addresses into your firewall for home network. Dave Link to comment Share on other sites More sharing options...
Guest Jacko_ Posted October 17, 2006 Share Posted October 17, 2006 Check your fire wall settings. Your router prob works on 192.168.2.1 or 192.168.1.1. You need to program a range of IP addresses into your firewall for home network. Dave Before you fitted the wireless router, was your desktop PC connect to the broadband router via USB?, only ask as the IP settings for the network card in your PC might not be set to automatic so it won't be given an IP address by the router Link to comment Share on other sites More sharing options...
Guest Posted October 17, 2006 Share Posted October 17, 2006 Before you fitted the wireless router, was your desktop PC connect to the broadband router via USB?, only ask as the IP settings for the network card in your PC might not be set to automatic so it won't be given an IP address by the router Easy way to try, find out what IP address the router home page should be set to. Load 'command prompt' from All programs-accesories. Type ping 192.168.2.1 (or whatever your router ip address is) and press enter. You should see loads of replies from router. If not change firewall settings and try again. Dave Link to comment Share on other sites More sharing options...
amateurandy Posted October 17, 2006 Share Posted October 17, 2006 Check the status of your LAN connection, then click on the Support tab. Click on Details then cut and paste the results here. Should look something like: Physical Address: XX-XX-XX-XX-XX-XX IP Address: 192.168.0.2 Subnet Mask: 255.255.255.0 Default Gateway: 192.168.0.1 DHCP Server: 192.168.0.1 Lease Obtained: 17/10/2006 18:57:29 Lease Expires: 20/10/2006 18:57:29 DNS Servers: 212.74.112.66, 212.74.112.67 WINS Server: Link to comment Share on other sites More sharing options...
hiro Posted October 17, 2006 Author Share Posted October 17, 2006 Check the status of your LAN connection, then click on the Support tab.Click on Details then cut and paste the results here. Should look something like: Physical Address: XX-XX-XX-XX-XX-XX IP Address: 192.168.0.2 Subnet Mask: 255.255.255.0 Default Gateway: 192.168.0.1 DHCP Server: 192.168.0.1 Lease Obtained: 17/10/2006 18:57:29 Lease Expires: 20/10/2006 18:57:29 DNS Servers: 212.74.112.66, 212.74.112.67 WINS Server: for that I now have my desk top connected but my laptop is having non of it Any comments or points i make are my own views and not that of my employer or company Link to comment Share on other sites More sharing options...
james.wilson Posted October 17, 2006 Share Posted October 17, 2006 Are both machines setup for DHCP or are you static addressing? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Guest Posted October 17, 2006 Share Posted October 17, 2006 Hey love the IP info, i have a new game to play now muwhhahahaahaha Link to comment Share on other sites More sharing options...
hiro Posted October 17, 2006 Author Share Posted October 17, 2006 go on then old hand what you gonna do, the only thing you might be able to attack is his dns servers!! All that is local netowrk ip's nothing external!! managed to get desktop and laptop on internet now need to sort out file sharing etc any clues? Any comments or points i make are my own views and not that of my employer or company Link to comment Share on other sites More sharing options...
hiro Posted October 17, 2006 Author Share Posted October 17, 2006 you need to setup a workgroup on both machines then share files etc, I assume they are bot xp home? Or get yourself a nice linux server and run a domain so much easier, but peer to peer is easy, there are wizards in xp under networking with the laptop being a wireless connection and desktop being hard wired do you setup a wireless on one and home network on other or both the same or am i barking up wrong tree? Any comments or points i make are my own views and not that of my employer or company Link to comment Share on other sites More sharing options...
