August 7, 200719 yr comment_174413 We have an old Sensormatic RA485LP. The only information available on the web for this ptz camera is in this forum in this thread. In my reading of that thread I pull out two useful pieces of information: 1) this is a two board unit 2) it supports AD422 protocol We need additional information however. 3) What is the pin assignment for the orange (power/data) connector? Ours does not have the cord. 4) What additional protocols, if any, does the unit support? 5) Is there any support documentation anywhere which can be used, even if it is for another model? Thanks in advance. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/20187-info-needed-for-sensormatic-ra485lp/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 7, 200719 yr comment_174424 dont fall into the trap that 422 is the same as sensormatic 422, our sales dept did at a cost of 8 grand Eucam Security Systems 0845 4630 746 www.eucam.co.uk Link to comment https://www.thesecurityinstaller.co.uk/community/topic/20187-info-needed-for-sensormatic-ra485lp/#findComment-174424 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 7, 200719 yr Author comment_174430 Thank you! AD422 can also mean "RS422". Thus the request for additional info. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/20187-info-needed-for-sensormatic-ra485lp/#findComment-174430 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 7, 200719 yr comment_174432 sensormatic/ad 422 is very similar to rs 422 but wont work correctly Eucam Security Systems 0845 4630 746 www.eucam.co.uk Link to comment https://www.thesecurityinstaller.co.uk/community/topic/20187-info-needed-for-sensormatic-ra485lp/#findComment-174432 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 8, 200719 yr comment_174470 I have a manual I can Email to you (PM me with your e-mail address) The connections you need are as follows:- Connector terminals to the top, looking at the back of the connector, pins are 1 to 7 from left to right Pin1 - TX Low Pin2 - TX High Pin3 - 24Vac Pin4 - GND Pin5 - 24Vac Pin6 - RX Low Pin7 - RX High Hope this helps Link to comment https://www.thesecurityinstaller.co.uk/community/topic/20187-info-needed-for-sensormatic-ra485lp/#findComment-174470 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 8, 200719 yr Author comment_174492 Thank you for the offer. PM sent. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/20187-info-needed-for-sensormatic-ra485lp/#findComment-174492 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
