Guest cliff Posted March 10, 2006 Share Posted March 10, 2006 Hi I have a Care Tech 1500 and have cut through the cable leading to the outside alarm box,I have re-joined the 6 cables and, done a walk through test and all the detectors work, when I do the Bell Test the outside alarm sounds and flashes, but the indoor alarm does not work, and I cannot set the alam on either full or part. Can anyone help, many thanks if you can. Link to comment Share on other sites More sharing options...
Guest rjbsec Posted March 10, 2006 Share Posted March 10, 2006 You need an engineer, anything may have happened - post where you are and someone here may be able to help. Link to comment Share on other sites More sharing options...
Guest G.J.M Posted March 10, 2006 Share Posted March 10, 2006 You need an engineer, anything may have happened - post where you are and someone here may be able to help. blown fuse? Link to comment Share on other sites More sharing options...
Guest ALSEC Posted March 11, 2006 Share Posted March 11, 2006 blown fuse? all day long.. Link to comment Share on other sites More sharing options...
Guest cliff Posted March 15, 2006 Share Posted March 15, 2006 Hi I'm in Bishops Stortford Herts - if anyone can help I'd be very gratefull. Thanks Cliff Link to comment Share on other sites More sharing options...
Guest cliff Posted March 15, 2006 Share Posted March 15, 2006 Thanks guy's blown fuse it was - it now works fine. Link to comment Share on other sites More sharing options...
Guest ALSEC Posted March 15, 2006 Share Posted March 15, 2006 You just so happened to have a panel fuse with you?? Link to comment Share on other sites More sharing options...
Guest G.J.M Posted March 15, 2006 Share Posted March 15, 2006 Thanks guy's blown fuse it was - it now works fine. what do i know eh Alsec? Link to comment Share on other sites More sharing options...
Guest ALSEC Posted March 15, 2006 Share Posted March 15, 2006 what do i know eh Alsec? by all day long I meant "yes - that would the problem all day long" - I was in agreement with you.. not a bad call for a fire guy!! Link to comment Share on other sites More sharing options...
Guest G.J.M Posted March 15, 2006 Share Posted March 15, 2006 ah i see. Multi skilled us fire chaps B) Link to comment Share on other sites More sharing options...
