Cut Wire
Guest cliff
Guest cliff
Hi
I have a Care Tech 1500 and have cut through the cable leading to the outside alarm box,I have re-joined the 6 cables and, done a walk through test and all the detectors work, when I do the Bell Test the outside alarm sounds and flashes, but the indoor alarm does not work, and I cannot set the alam on either full or part. Can anyone help, many thanks if you can.
Guest ALSEC
what do i know eh Alsec? :P
by all day long I meant "yes - that would the problem all day long" - I was in agreement with you..
not a bad call for a fire guy!!
