Simon_D Posted August 14, 2005 Share Posted August 14, 2005 i have a veritas R8 installed. all working fine and programmed, but the only problem is i cannot change the PIN. the book says enter the engineer code, press 60, enter new pin code, prog, then reset to go back to 'unset'. however, when i do this, it changes the engineer code, and not the PIN code. what am i doing wrong? EDIT: have found out how to do it. didnt relize you have to use the PIN then prog to change it Link to comment Share on other sites More sharing options...
breff Posted August 14, 2005 Share Posted August 14, 2005 Doh!! The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment Share on other sites More sharing options...
