ADE Karizma system dead
Guest Jatinder
Its not! - go into "my controls" at the top of the main forums page, then go to OPTIONS section "board settings" then click or check the daylight savings button then click "change my account options" at the bottom of that screen - jobs a goodun :)
55378[/snapback]
Only works for members. Otherwise, spot on Dave. ;)
Administrator, the forum clock is one hour out!!
cheers, Jatinder
55376[/snapback]
He is a member LOL - just not signed in look at the end of his post ;)
Eh?
What is there at the end of his post that makes you think he is a member?
You been in the sun too much mate, I'd go for a lie down if I were you!
EDIT: Just seen your other reply, glad you've seen the light. ;)
Guest Guest
I'm not a member - I'm a "Guest"
The alarm is now active but I'll change the battery and check if the circuit is charging it.
Thanks to some of you with the helpful feedback. My brief visit to the security installer forum was interesting - do you have a special handshake comrades!!!
Guest ALSEC
The battery is pulling the rest of the panel down voltage wise, and it may have/could damage the Panel, get someone local to you to call out and have alook at it as they may be able to save the system and service it rather than replacing it for you.
55304[/snapback]
Sorry mate I have to disagree, I think the problem is that it's a Karisma. Going wrong is the best thing that could have happened to it - take it out and replace with a proper alarm.
(not wrong about the batt bit, of course your're right there)
