Guest alyeti Posted February 27, 2005 Share Posted February 27, 2005 Hi Got problem i have done this before and its worked fine but something is a miss and its doing my head in. Installation manual says Terminal B is not used on I/O Mod but REM page description shows A-A B-B C-C D-D Panel to REM so which is correct? Also Chapt 2.2 shows ABCDEF existing on REM but REM i have only has ABCD RLY and 0v i know RLY and 0V is to energise relay etc . Am i forgetting something or am i supposed to intialise the REM in the engineers menu on Zones to what ever i want above the 6 then connect the REM? think i've lost the plot but done them before loads been a while and have lost the plot help me out please. Link to comment Share on other sites More sharing options...
morph Posted February 27, 2005 Share Posted February 27, 2005 Terminal B,C,D are common to all rems. A to zone A To program the rem on the system power down the panel, then power up, within 6seconds while the sisplay is showing the power up message "0* NO YES" (where * is the number of rems" this tells the system how many rems are on the system. you also have the wrong instructions as you have the older REM. Link to comment Share on other sites More sharing options...
Guest alyeti Posted February 27, 2005 Share Posted February 27, 2005 Ok I know how to program REM so are you saying REM is ok to wire A-A B-B C-C D-D? Link to comment Share on other sites More sharing options...
morph Posted February 27, 2005 Share Posted February 27, 2005 a being A on the sone you are using and B,C,D being on the terminal marked REM. When you program it as I mentioned the zones become(if connected to zone 1) 1a,1b,1c,1d,1e,1f,1g,1h Link to comment Share on other sites More sharing options...
Nova-Security Posted February 28, 2005 Share Posted February 28, 2005 Would be nice to know what panel it is, On the left hand side of the board does it have 1,2,3,4,5,6,7,8,b,c,d ? www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
morph Posted February 28, 2005 Share Posted February 28, 2005 Read the Topic heading If you have a 6/14 it is not compatible with a rem. You need a IO mod the rem will only work with an 8/80 or the old ab 15. Pete 42056[/snapback] It does help Link to comment Share on other sites More sharing options...
Nova-Security Posted March 1, 2005 Share Posted March 1, 2005 Does Help, read the topic clever........ Abacus 6/14 wont take a rem anyway as pete said......Mr AlarmGaurd i think we both read this one wrong........ wheres my glasses Now try explaining the wiring of a zone splitter or if a new software version the Pear Drop thingey. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
morph Posted March 5, 2005 Share Posted March 5, 2005 We did Link to comment Share on other sites More sharing options...
