Guest rafal Posted January 6, 2005 Share Posted January 6, 2005 Hi all Just installed 10 Impaq Plus sensors. The sensitivity pot Is adjusted to roughly same setting /let say 10 o Link to comment Share on other sites More sharing options...
Brian c Posted January 6, 2005 Share Posted January 6, 2005 Swap one of the 'good' ones with one of the other two. If the problem (I assume you mean they won't pick up as well as the others) is still there, then it is due to the location of that sensor. If the problems goes away, it suggest faulty equipment. If you don't know......ask. Link to comment Share on other sites More sharing options...
Guest rafal Posted January 6, 2005 Share Posted January 6, 2005 Swap one of the 'good' ones with one of the other two. If the problem (I assume you mean they won't pick up as well as the others) is still there, then it is due to the location of that sensor. If the problems goes away, it suggest faulty equipment. 36249[/snapback] Thanks, that confirms my suspicions Link to comment Share on other sites More sharing options...
Guest RICHL Posted January 6, 2005 Share Posted January 6, 2005 what are you using for the "bang" test? Link to comment Share on other sites More sharing options...
Guest rafal Posted January 6, 2005 Share Posted January 6, 2005 what are you using for the "bang" test? 36299[/snapback] A pointy screwdriver handle Link to comment Share on other sites More sharing options...
Brian c Posted January 6, 2005 Share Posted January 6, 2005 A pointy screwdriver handle 36300[/snapback] Ah, the choice of professionals. If you don't know......ask. Link to comment Share on other sites More sharing options...
Guest rafal Posted January 7, 2005 Share Posted January 7, 2005 Ah, the choice of professionals. 36301[/snapback] One picks up things here as one reads Link to comment Share on other sites More sharing options...
Guest RICHL Posted January 7, 2005 Share Posted January 7, 2005 Link to comment Share on other sites More sharing options...
breff Posted January 7, 2005 Share Posted January 7, 2005 I usually use my mobile phone..................................... That reminds me, whats Carphone Warehouse Repair Centre number again? The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment Share on other sites More sharing options...
