PowerMaster 10 – Trouble resetting after power cut
Hi all,
I’ve got a Visonic PowerMaster 10 panel and after a recent power cut, it’s showing a “system not ready” message and won’t arm. I’ve checked the battery and power supply, and everything seems fine now. Is there a reset process I need to follow or something I might be missing?
Cheers!
If you keep pressing the info/OK button it should run through the faults.
If the faults are clear it will let you arm/disarm to clear.
