November 4, 20224 yr comment_516832 Hi I want to update my Texecom Veritas panel which has been in for about 15 years and noticed that the external case has gone dark yellow because of the heat sink. Looking to replace it with the Premier Elite 24 plastic case but not sure if there would be the same heat build inside due to its compact size or should I go for metal? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45369-texecom-panels/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 4, 20224 yr comment_516833 Switch mode power supplies and the regulator is off the board so will not be the same. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45369-texecom-panels/#findComment-516833 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 4, 20224 yr Author comment_516834 So I presume they run cooler then the old power supplies? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45369-texecom-panels/#findComment-516834 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 4, 20224 yr comment_516835 Completely different panel and power supply setup. Premier will be a fair bit more in depth to program. A plastic cab will always yellow slightly with age but not go brown in the top left like some Veritas do. Normally that's a sign that the power supply has been heavily loaded, should do current checks. The Metal cab has a larger power supply and battery capacity, if that's a concern. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45369-texecom-panels/#findComment-516835 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 5, 20224 yr Author comment_516839 Thank you for your help and advice. Think I will go for Metal cab with larger power supply as maybe having 3 sounders connected to the Veritas has been drawing to much power from the power supply. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45369-texecom-panels/#findComment-516839 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
November 5, 20224 yr comment_516841 Sounds like too much current for most panels, would need to do standby and load current checks to make sure the battery and power supply is suitable. That Veritas sounds very overloaded. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/45369-texecom-panels/#findComment-516841 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
