Visonic powermaster 30 user code
Hi i'm installing a visonic powermaster 30 and have problems with unlocking it with my user code  on full set, it unlocks fine on part set and once the alarm activates on full set it will unlock. anyone have any ideas where i'm going wrong Cheers
18 minutes ago, gazza_2 said:
Hi i'm installing a visonic powermaster 30 and have problems with unsetting it with my user code  on full set, it unsets fine on part set and once the alarm activates on full set it will unset. anyone have any ideas where i'm going wrong Cheers
Ive changed your wording so it makes more sense
Its sounds like its set up for monitoring, which means you have to use the fob to unset not the code
thanks so much will look in to that, do you know if that's a setting? sorry thanks for changing it for me i could not think how to word it
Edited by gazza_2
