Newbie1 Posted March 25, 2018 Share Posted March 25, 2018 Are there particular issues to be aware of when doing a Texecom Elite firmware upgrade. For example the documentation says disconnect the power and reconnect it before starting. I assume this means both mains power and battery power? If so is there a chance that the internal or external sounders will go off? Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted March 25, 2018 Share Posted March 25, 2018 You can't flash a powered down panel. There are certain caveats on some versions of firmware but it's similar rules as flashing/updating any device firmware. If major version change you will need to default. Sounders may sound for a second or so when switching between Prog and Run. Quote Link to comment Share on other sites More sharing options...
