Oculi
Recently, we got an Oculi camera that have just been released.
This camera is fully functional off only a sim card and a battery - no other source required. Using a roaming sim and a data plan.
Currently being used to overlook a defibrillator in a local town, and so far doing well. We have altered this slightly to what we needed. Instead of a PIR activating and recording on a public path - activated through a contact onto the box from the inside. Using the app will take a short video of when the contact activates, notifying you and storing for you to look at. Heartbeat set up so far to only once a day giving a 3 second recording of view from inside the box. Going well.
Looking forward to finding out more and how much this camera can really do.
Needs defibbing?
15 hours ago, norman said:
Needs defibbing?
Well we hope not..
What’s the projected battery life?
The app shows us a projected battery changed with almost like a speedometer showing the battery usage - around 2 years dependent on usage and heartbeat frequency etc.
We will keep an eye on this, may not be 100 percent reliable as only testing but will be getting serviced throughout its lifespan
UPDATE - Camera is still working well, we have a picture to post of the camera inside the defib. Image was during a heartbeat set on the app. So far so good
