False alarm issue
  • Replies 32
  • Views 5.3k
  • datadiffusion
    datadiffusion
    Could have been an MI5 / TV detector van shifting a recently crashed UFO across the county whilst trying to stop Trump publishing details of Kennedy...?
  • does the alarm relay also open on AM ?   is the sensor nr a door ?
  • Just found it 24.200ghz miles out
Alarm relay does seem to open on masking everything else opens the trouble relay but that's not in use according to manual
I'm thinking relocate opposite corner and recable see how it goes sound reasonable?
So you have changed the detector?
you have swapped the cores used inside the cable?
You have swapped the zone used ie from main panel to node.
and you still get the same result?
is it going Alarm or is it Tamper when it activates?
i would strongly suggest it is environmental or could be a cable issue still, when you swapped cores around how did you do it?
swap Alarm pair for tamper pair? Or did you have an 8 core there?
Hi yes I've changed from a circuit in the panel to a circuit on An expander I've changed the detector and I've changed cores multiple times to all different colour combinations 8 core (using two cores as on resistors) and is going into Alarm condition
How strange, to satisfy curiosity In this situation I would swap the detector with one from a different room just to make sure, as you know the others don't false alarm.
i would also look at why the suppressor is there and how bad is the ac leakage.
when it was on the node was it the first zone?
Hi I put the surpressor on when I fitted it votages were all ok I put it on as a prevention for the future and yes is very strange never had something as perculiar before
^ What he said. One at a time and 'faulty' detector should either be swapped (or go on standalone test rig to soak etc...)
