August 25, 20179 yr comment_467803 Greetings all, need some help and advice plz. A friend of mine has a scantronic 9651 with smoke detectors fitted. The problem is he would an electronic sounder fitted because it only bleeps at the keypad. Is there a way to fit say a 12v roshni to the panel via the 12v aux or the n/o-n/c contacts. thanks in advance Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41509-scantonic-9651-fire-alarm/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 25, 20179 yr comment_467804 There is already a speaker output on the 9651 which will produce many tones including a distinctive one for the fire alarm. You can have up to two speakers so ideal for hallway and 1st floor. The output is marked LS + or SPKR depending on version. They are always next to the siren outputs. Suitable speaker - http://cpc.farnell.com/lynteck/ly07-009-37/extension-speaker/dp/SR04341 Don't bother trying to connect anything to the detectors themselves as it won't be re-settable from the panel and will drive them mad. However, although approved under certain circumstances bear in mind this sort of setup is more vulnerable to failure in a fire situation of through neglect of the alarm system eg. system batteries. So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41509-scantonic-9651-fire-alarm/#findComment-467804 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 25, 20179 yr Author comment_467805 That's brilliant, thank you very much . Link to comment https://www.thesecurityinstaller.co.uk/community/topic/41509-scantonic-9651-fire-alarm/#findComment-467805 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
