Dahua Cameras fault "Abort" and "Startup"
Anybody else suffering with Dahua IP Cameras rebooting very repeatedly...?
Currently trying to configure one for a Job, and noticed repeated rebooting. Initially replaced the PSU, then tried POE but still occuring...
Checked 2 other cameras that have been working well for many months and noticed both started a similar pattern this morning..
Logs show
Abort, Startup then Hot Swap...in that order.
My initial thought was a dodgy SD Card, but not all have Edge recording
Bit confused as to whats going on and what has caused it to occur...?
Not got any issues as yet, got quite a few out there now
infact we are finishing off a 60 cam install at the mo, no issues as yet
mixture of wedge cams and bullets
Tried defaulting the new camera and one of the original cameras and the issue is still occuring...?
It does appear to be some sort of conflict... When not connected to router, seems to be more stable and doesnt want to reboot..
I should have explained the cameras mentioned were on a separate site 8 miles away
Checked the switch range - all ok, but now sorted with a Firmware Update.... Very interesting that 2 cameras that were working well, went wrong on the same day...
