I have an Abacus 6 which I installed sometime back.
Due to room modifications I want to remove one PIR from the system.
After disconnecting at the panel, can anyone advise on how to remove this zone from the keypad display?
Thanks.
Thanks for that.
Will it just be a case of removing the wires at the panel, 6 wires to the PIR or will I need to bridge any terminals in the panel, zone, tamper?
Presumably just disconnect the 12v +/- supply.
Will probably jog my memory when I remove the cover.
Register a new account
Sign in
