Scantronic 9427 Control Panel Issue
LouisW
Hi
Perhaps someone has some idea of the problem, that can help. Our alarm went off a few weeks ago, while we were on holiday. The neighbor came in and reset using the PIN - panel showed a red light on zone 2.
We have never then reset the panel, as the kids have been at home all day. Perhaps this was a mistake.
Last night the alarm went off again - this time the panel showed a green light on the top icon - a short dash, with a small "squiggle" above it.
All went off after a while.
Then the control panel sounder activated, this time showing the green padlock icon.
This morning, all is quiet except the panel is now showing the hammer icon - is this a break in sign?
The manual is no help - all I want to do is reset the system and start over!
I have noticed the control box, Scantonic 9448 under the stairs is flashing a green icon - maybe this is just showing it has power?
Any help would be appreciated - especially for all my poor neighbors!!
I would call a professional to disable and quote for replacement, this is a very old, obsolete system.
As you can see it's biggest problem is that any faults are communicated in an obscure way, rather than the plain English
text a replacement system would likely use.
I suspect that at the very least you will need a new system battery.
  • 1 month later...
Hammer Icon = system Tamper
flashing green light is a Power Fault
The installer manual is easily available via the internet
BUT.. if you don't know or not confident in what you are doing i would suggest you call an engineer to check your system
Just because its old wont mean its not serviceable and  a good engineer will be able to give you sound advice
Thanks for the post Swiftey, but the OP posted this a whole month ago and has never revisited the forum since that date.
It would be great to introduce yourself in the... Introduce Yourself forum :)
