fabzster Posted August 18, 2015 Share Posted August 18, 2015 Hi All I am new to alarm systems, but find them interesting and currently upgrading my Old IDS system to a new Paradox MG5050 system. I was hoping that I could get some advice here, once complete I was thinking of creating a tutorial to help other DIY users. I have 3 x wired panic buttons that were in place from the previous system and 3 x Wireless REM101's I have added 3 x REM101's via Winload and made Button A/PGM Action 1 [8] Panic I have selected Zone1 as the panic zone (I assume I connect 3 x Wired Buttons to Zone1) I am then not sure what to select on PGM1 (For Panic) Do I select a Group and make all the wires panics belong to Group#8? And for PGM2 for the Normal Alarm to go through, what do I set that to? And then how should I wire My ADT Radio to the Board & PGMS’s? Any assistance would be appreciated. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted August 18, 2015 Share Posted August 18, 2015 Never used this panel, but pgms are your outputs yes? As in optional outputs and the provided the zone is programmed as a panic should work regardless of the pgm output? Can you not put each button on its own zone? Easier to identify then Quote Link to comment Share on other sites More sharing options...
