diyman207 Posted September 6, 2014 Share Posted September 6, 2014 (edited) Hi. I changed the install and config codes a while ago for a powermaster 30 G2 panel, and I cannot remember them. Is there a way to reset them? I guess a full factory reset is an option, but I have seen elsewhere in these forums that for the power max, shorting 2 particular pins does the job. Edited September 6, 2014 by diyman207 Quote Link to comment Share on other sites More sharing options...
norman Posted September 6, 2014 Share Posted September 6, 2014 Hi, unfortunately and for obvious reasons we are unable to give out defaulting codes or information. Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
diyman207 Posted September 6, 2014 Author Share Posted September 6, 2014 Hi, unfortunately and for obvious reasons we are unable to give out defaulting codes or information. So what should I do then? Quote Link to comment Share on other sites More sharing options...
morph Posted September 6, 2014 Share Posted September 6, 2014 Speak to the supplier of your alarm. Quote Link to comment Share on other sites More sharing options...
diyman207 Posted September 6, 2014 Author Share Posted September 6, 2014 OK. Will do. They're not open on Saturday though. Quote Link to comment Share on other sites More sharing options...
morph Posted September 6, 2014 Share Posted September 6, 2014 That's one of the problems that you get with a diy installation, the level of support can be non existent when you need really need it. The perceived benefit of DIY over Professional install is generally one of cost, but one of the main benefits is that support is a available 24/7 365 days a year. Quote Link to comment Share on other sites More sharing options...
