Fire Alarm System Into Intruder Alarm
Sounds good to me. And for a non pro carrying out this work fair play, because there are a lot of engineers out there that would have issues doing this.
Need any help please revisit.
Good luck bud !
Thank you! I appreciate that alot.
I'll be sure to keep everyone informed ... as I run into troubles along the way no doubt.
Guest old-hand
Just to stop you for a second.
Did you work out the loadings independently for the panel and PSU. As they will not be powering each other under a mains fail.
As you gave a total power consumption in your calculations.
cheers
cheers
No that was overall.
So the PSU is not wired into the Panel (for power sharing) its just A&B lines linking the two ?
May mean that I will need more backup power in the PSU than in the Panel.
Worst case is that I put the biggest physical battery I can in each of the Panel and PSU.
your 1A galaxy will only support a 7A/h however your 3A smart psu will support a 17A/h
I would load the panel the lightest so that the smart ran out first. YOu can use that application of ours to work out the loading accross each supply
