ArsMoriendi Posted April 28, 2009 Share Posted April 28, 2009 Chaps Am I right in thinking that the Prestige Quad PIR does not have EOL resistors in it, but the AMQD Plus, does ? Thanks! Link to comment Share on other sites More sharing options...
Rulland Posted April 28, 2009 Share Posted April 28, 2009 The prestige QD has built in jumpers for: Tamper 1k,2k2,5k6 Alarm 1k,4k7,5k6 As does the AMQD etc. Obviously if your connecting to a panel (R8+ eg) you will need to insert the relevent resistors for that panel and select O/C on the jumpers in the PIR. Richard. Link to comment Share on other sites More sharing options...
ArsMoriendi Posted April 28, 2009 Author Share Posted April 28, 2009 The prestige QD has built in jumpers for:Tamper 1k,2k2,5k6 Alarm 1k,4k7,5k6 As does the AMQD etc. Obviously if your connecting to a panel (R8+ eg) you will need to insert the relevent resistors for that panel and select O/C on the jumpers in the PIR. Richard. Well, curses. Thanks for the info. Nowhere on the Texecom PDF does it tell you that http://www.texe.com/document.php?docid=392 I've just ordered 7 AMQD's, because the PDF for that one says it has the resistors in. The rest of the components are all grade 3, so I suppose the PIR's may as well be. Ars Link to comment Share on other sites More sharing options...
Rulland Posted April 28, 2009 Share Posted April 28, 2009 Obviously an old library brochure cos the pic doesn't show the jumpers! , whereas the install guide does!. They're on the left hand side of the PCB. Link to comment Share on other sites More sharing options...
dogzb Posted April 29, 2009 Share Posted April 29, 2009 I received prestige QD and DT today, both with jumpered resistor selection ... the DT has a separate addendum to its instruction sheet specifically covering this - my guess is a design change or this was missed from the original documentation. Link to comment Share on other sites More sharing options...
